MMacg
6 years agoTiming constraints to use with EPCQ128A on Cyclone10 LP Evaluation Board
Hello. I have been trying to constrain four paths that are being reported as unconstrained in Timing Analyzer in Quartus Standard as shown below: nios:nios_i|nios_epcq_controller2_0:epcq_controlle...
KhaiChein_Y_Intel
6 years agoHi,
The signal delay from FPGA or flash memory device to the PFL synchronous input port is specified by set_input_delay. The delay calculation is:
Input delay value = Board delay from FPGA or flash output port to the PFL input port + TCO of the FPGA or flash memory device
The signal delay from PFL synchronous output port to FPGA or flash memory device is specified by set_output_delay. The delay calculation is:
Output delay value = Board delay from the PFL output port to the FPGA or flash input port + TSU of FPGA or flash device.
Reference: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf Chapter 1.4.2.2. Constraining Synchronous Input and Output Ports
