12 years agoTiming Constraint problem on set_input_delay for Video LVDS Rx
Hi,I encountered another problem. If a input signal is data and also clock,like LVDS transceiver for video,then there is a problem. create_clock -add -name {Ext_LVDSClkA} -period 16.666 -wavefo...
12 years agoI want to capture the LVDS_A_CK with the clock INT_IOCLKA generated by PLL following the timing in the visio.So I do the timing constraints as follows.
set_max_delay -from {LVDS_A_CK} -to {LVDSRxTop:u_LVDSRxTop|lvds_rx:u_lvds_rx0|r_LVDSClk[0]} [expr 1.099 + 2.197] set_min_delay -from {LVDS_A_CK} -to {LVDSRxTop:u_LVDSRxTop|lvds_rx:u_lvds_rx0|r_LVDSClk[0]} [expr 1.099 - 2.197] 2.197 is the half of Cycle of INT_IOCLKA,and 1.099 is the shift phase value of INT_IOCLKA. Are the timing constraints right?
