ATsao3
6 years agotiming constraint for output mux and how to set output delay.
Hi, I’m looking for some help to constraint my design. I didn’t write constraint before and i look some documents on internet. Still can’t find any example similar to my design. My design has two i...
sstrell
6 years agoYou're essentially creating a source synchronous single data rate (SDR) output interface. There's quite a few constraints involved, so check out this training first:
https://www.intel.com/content/www/us/en/programmable/support/training/course/ocss1000.html
You'll need a generated output clock constraint, output delay constraints, a false path constraint for the clock, and potentially a multicycle exception. Post again if you want a check of your code after seeing the training.
#iwork4intel
