11 years agoTiming constraint for 1000Mbps Small Mac in Quartus 14.0
Hi All, Quartus has stopped generating an automatically generated timing constraint file after Quartus 14.0 and I am having problems in constraining the 1000Mbps Small Mac. The design is fully ...
11 years ago --- Quote Start --- Yes that much I understand and the interface I'm using for my external Ethernet is rgmii. --- Quote End --- You might have a look at this example from Altera. http://www.altera.com/support/examples/interfaces-peripherals/exm-tse-rgmii-phy.html However, as I recall the Ethernet independent examples in Time Quest User's Guide follow on for source synchronous timing are a good place to start. http://www.alterawiki.com/wiki/source_synchronous_analysis_with_timequest
