NShan12
5 years agoTiming analysis error on Asynchronous control signals
In my design, there is an asynchronous bus between FPGA and Microcontroller (Master). FPGA uses the edges on the signals WRN (Write active) and ALE (Address Enable) to classify if the signa...
sstrell
5 years agoYou're coding them like clocks so the tool will think they're clocks.
What do your false path constraints look like?
- NShan125 years ago
The false path constraints are as follows:
set_false_path -from [get_ports WRN]
set_false_path -from [get_ports ALE]
