Timing analysis error on Asynchronous control signals
Set the signals as false paths.
Yes, I had set false paths on them. But Timing analyzer report still shows these two signals as unconstrained clocks in the clock status summary.
My Code:
--somewhere in the architecture
PROCESS ( ale, adbus )
BEGIN
IF ( ale'event AND ale = '0' ) THEN
address <= adbus;
END IF ;
END PROCESS;
PROCESS ( wrn, clearn, adbus )
BEGIN
IF clearn = '0' THEN
data<= "0000000000000000" ;
ELSIF ( wrn'event AND wrn = '1' ) THEN
data <= adbus( 15 DOWNTO 0 );
END IF ;
END PROCESS
I am using the edges of ALE and WRN to identify if it is address or data on the adbus, and the tool thinks these are clocks.
There are also warnings:
Warning (332060): Node: wrn was determined to be a clock but was found without an associated clock assignment.
Warning (332060): Node: ale was determined to be a clock but was found without an associated clock assignment.
