16 years agotimescale related query ..
Can anyone explain why the simulator shows the following output for the below verilog code : Output : run # 0x Thanks a ton in advance! -----------------------...
16 years agoWell you are asking me to dig pretty deep into memory but I believe the "run" command alone will run a single timestep. In your case that is 10ns.
If you want to run the simulator to the end of the simulation you issue a "run all" command. However, you must define what the "end" of the simulation is. Typically the end is indicated by either a "$finish" or "$stop" directive in your testbench. If you don't have something to stop the simulation in the testbench, it will run indefinitely. Jake
