16 years agotimescale related query ..
Can anyone explain why the simulator shows the following output for the below verilog code : Output : run # 0x Thanks a ton in advance! -----------------------...
16 years agoThanks for the reply to both of you :)
Yea i find that if I issue "run 400" it shows the complete simulation result. That means that when we are issuing "run" command, the compiler executes only uptil a certain time instant .... And that's now a concern...how does the compiler decide this time for which simulation is done for a single "run" command. One observation is , if I change the timescale to : 'define timescale 1ns/1ns and then do : run I get the complete results at once....ie at least upto simulation time 31 ns.... run # 0 x # 20 1 # 31 0 So the question that bothers is how we know what is this timestep that "run" command executes for ? Thanks a lot again !
