16 years agotimescale related query ..
Can anyone explain why the simulator shows the following output for the below verilog code : Output : run # 0x Thanks a ton in advance! -----------------------...
16 years ago --- Quote Start --- Can anyone explain why the simulator shows the following output for the below verilog code : Output : run # 0x Thanks a ton in advance! ---------------------------- `timescale 10ns/ 1ns module toy ( a, sel, y ); input a,sel; output y; reg y; initial $monitor ( $time, y ); initial begin #0 y = 1'b0; #20 y = 1'b1;# 11.1 y = 1'b0 ; end endmodule --- Quote End --- Hi, the signal y is not defined from 0 until 20ns. Thats why you got the 0x. Kind regards GPK
