17 years agoTimequest: WHY?
Sincery I cannot understand why Altera wanna loose the best advantage that it has with its competitors: the integrated quartus II features! I mean: I understand that Timequest is very beautiful...
17 years agoThanks you for your answer.
Some of the tricks you've given were nice to know - in the specific in the sdc "editor" - (all the others I've found them all the guide here in Altera forums). The most think that I miss from Classic Time Analiser is the ability to right click on a part of the schematic entry or on a name in the vhdl files and can add constraint without looking all over with the netlist with the View->NameFinder (REMEMBER TO CLICK the HIERACHY tick to look into all the design). Moreover another important thing is the -asyncronous I've used the -exclusive that work in the same manner but with only 2 groups each time.. So I've done a lot of constraint for this issue (didn't know the -asyncronous and neither the FAE that I've asked it..) I suggest if you can to edit the "TimeQuest CLocks Quick Start Guide" that you've posted here on the Altera forum (link: http://www.alteraforum.com/forum/showthread.php?t=790&highlight=timequest+clocks+quick+start+guide). Maybe put it as a Sticky post together with the others guide you've done very well such as: - http://www.alteraforum.com/forum/showthread.php?t=1845&highlight=timequest+clocks+quick+start+guide - http://www.alteraforum.com/forum/showthread.php?t=5026&highlight=understanding+recovery+removal+analisys I found them very usefull. Thx a lot for your suggestions and job
