16 years agoTimequest report slack negative on recovery
QII shows these warning:
Warning: Ignored assignment: set_false_path -from [get_keepers {*rdptr_g*}] -to [get_clocks {*ws_dgrp|dffpipe_gd9:dffpipe9|dffe10a*}] Warning: At least one of the filters had some problems and could not be matched Warning: *rs_dgwp|dffpipe_fd9:dffpipe6|dffe7a* could not be matched with a clock or keeper or register or port or pin or cell or partition Is these warning cause the recovery timing fail? The launch clock is constrainted with 25MHZ and the latch clock is constrainted with 165Mhz. Is this possible? Any others possibility that cause the recovery timing fail? Your helps is much appreciated. Many thanks....No RepliesBe the first to reply
