16 years agoTimequest Report Metastability
Timequest seems to ignore all synchronization chains except those contained in a megafunction DCFIFO. For example with the following clock definitions: create_clock -period "30.000 ns" -name ...
16 years agoGood point. If you pro-actively identify synchronization registers and have your own hierarchy that does it, then it's a great methodology. Of course the constraint has spaces in it, which makes the syntax a little questionable, but the following seems to work:
(* altera_attribute = "-name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS" *) reg [1:0] sync;
