14 years agoTimeQuest Constraints
Hello, I have the following lines of code from a .ucf file that I need to convert for the TimeQuest Timing Analyzer. net "dff_q_p" offset = in 4 ns before "clk_125_prebuf" high ; net "...
14 years agoI believe the first one is just an I/O constraint that works the same way as set_input_delay. (I always forget the BEFORE/AFTER difference, although they are opposites).
Are mem_data and mem_addr I/O pins? If so, set_max_delay should work fine. Remember that if you also have any set_input/output_delay constraints on those ports, they will be added into your set_max_delay analysis.
