14 years ago
TimeQuest Constraints
I have the following lines of code from a .ucf file that I need to convert for the TimeQuest Timing Analyzer.
net "dff_q_p" offset = in 4 ns before "clk_125_prebuf" high ;
net "controller/mem_data<0>" tnm_net = "mem_data";
net "controller/mem_addr<0>" tnm_net = "mem_addr";
TIMESPEC "TS_DS_address" = FROM "mem_data" TO "mem_addr" 8 ns;
should i use the set_max_delay command?
thanks!
    Appears do by Xilinx notation, right?
    You can use the SDC Editor to "synthesize" SDC compatible commands.
    Another question:
    Why is there a 8ns delay between ADR and DAT??
    Strange...
    I believe the first one is just an I/O constraint that works the same way as set_input_delay. (I always forget the BEFORE/AFTER difference, although they are opposites).
    Are mem_data and mem_addr I/O pins? If so, set_max_delay should work fine. Remember that if you also have any set_input/output_delay constraints on those ports, they will be added into your set_max_delay analysis.
