8 years agoTimequest constraints for a dynamically phase-shifted PLL
I've been trying to properly constrain a design that uses dynamic phase shifting of an instance of an altera_pll core that I created. I.e. to enable phase-shifting I checked the "enable access to dy...
8 years agoI assert that:
1) Setup and hold times are being met - the timing analysis report says so - for each phase. 2) The shifting and opening of the window was needed and was done properly - for each phase. 3) The bitmaps and my pasted timing constraints support these conclusions. I don't think we have any disagreement, except about the multicycle constraints - do you think they're incorrect? If so, how?
