8 years agoTimequest constraints for a dynamically phase-shifted PLL
I've been trying to properly constrain a design that uses dynamic phase shifting of an instance of an altera_pll core that I created. I.e. to enable phase-shifting I checked the "enable access to dy...
8 years agoYeah, it fails timing without the relaxed constraints, because there's a default setup relationship of 416.66 picoseconds for the 45-degree phase shift (because the phase shifted clock is running 300MHz therefore a 3.333 nanosecond period, and then the divide by eight for the phase shifts).
