8 years agoTimequest constraints for a dynamically phase-shifted PLL
I've been trying to properly constrain a design that uses dynamic phase shifting of an instance of an altera_pll core that I created. I.e. to enable phase-shifting I checked the "enable access to dy...
8 years agoHi vlrean,
Items 1 thru 6 you list are already done - my timing is fully constrained, and there are no errors reported. ] As I understand you have some timing related issues when running on hardware but TimeQuest reports say that there are no timing errors in all corners? Correct. ] Maybe you have added some false path exceptions where you should not? Yeah, that was one of the first things I thought of, but the affected path has the correct timing relationship, as verified by Timequest's reports.
