The Webdition should be able to modify and compile these projects.
the limitation should be that you won't be able to generate production code meaning the stuff will only work as long as there is an active jtag connection to quartus and or only 1 hour after reset und must be restartet. so evaluation on your desktop shouldbe possible
things may have changed with quartus v9.
as i have the subscription edition.
there is a nios package available maybe you need to install it too ?
but you could install the subscription edition and if it askes for a licence then you enable 30 day trial
with quartus up to 8.1sp2 it was possible to generate a new project open sopc create your own system and then compile via quartus and run it on the target. but no production possible
so i guess this must be possible with quartus 9
