17 years agotime-limited licence problem
Hi all, I modified the Quartus II Project File using SOPC builder and then recompiled it using Quartus II so the file got generated with the time-limited licence version of the Quartus II. Now I a...
17 years agoThanks for the so much useful information!
I have configured the hyperterminal as per the uart settings in system.h file. I did not check the txd line but even if I constantly send a character it is not received on the hyperterminal. uart is labeled uart_0 inside sopc builder and system.h as well. I am able to run jtag_uart and other example programs. I will try monitoring the registers in the debug mode as you have suggested. Is signal trap also available in the debug mode because it was not mentioned in the tutorial? Kindly guide me about how to proceed developing applications using peripherals using cycloneII. Thanks a lot!!!
