time-limited licence problem
Hi all,
I modified the Quartus II Project File using SOPC builder and then recompiled it using Quartus II so the file got generated with the time-limited licence version of the Quartus II. Now I am not able to burn the time_limited.sof file on the board. How to overcome this problem? Thanks & Regards, Nishant16 Replies
The problem is solved and I could create the project successfully.
There was a space in the project path which was causing the error. Thanks for the reply!!! - Altera_Forum
Do you have a space in your project path? It's the primary source of strange error messages in the IDE
I have a built a project using in 'Embedded_Systems_Lab ' from http://www.nioswiki.com/embedded_systems_lab. But when I try to create an application using this built system I get the error "Software Settings (STF) file associated with thi project is damaged Reason : java.net.MalformedURLException: unknown protocol: c". How to overcome this problem? Thanks a lot - Altera_Forum
In the SOPC builder, in the 'Board' drop down box there is no CyclneII(EP2C20) option so I select the 'Unspecified Board' option but files so generated do not work.
The Webdition should be able to modify and compile these projects.
the limitation should be that you won't be able to generate production code meaning the stuff will only work as long as there is an active jtag connection to quartus and or only 1 hour after reset und must be restartet. so evaluation on your desktop shouldbe possible things may have changed with quartus v9. as i have the subscription edition. there is a nios package available maybe you need to install it too ? but you could install the subscription edition and if it askes for a licence then you enable 30 day trial with quartus up to 8.1sp2 it was possible to generate a new project open sopc create your own system and then compile via quartus and run it on the target. but no production possible so i guess this must be possible with quartus 9 - Altera_Forum
Hi MSchmitt,
I have "Cyclone II EP2C20F484C7" on the board and I have full_featured, small, standard etc versions for niosII_cycloneII_2c35 which do not work on my board. I do have a few EP2C20F484 based project files in Altera\Kits\CycloneII_Starter_Kit-v1.0.0\Examples\ directory which I can not modify and compile due to web edition of quartusII. What do I need to do to develop my own applications with the available resources? I am also downloading NiosII and QuartusII 9.0 web edition but does it support "Cyclone II EP2C20F484C7" chip? Because with 9.0 also I won't be able to modify the project files. Thanks - Altera_Forum
Thanks MSchmitt for clearing even the smallest and so many doubts & questions and guiding so well.
Thanks a lot. - Altera_Forum
if you want to upgrade, just visit the altera web site, follow the link to the download center (top right corner of the main web site)
if you have a paid licence the go for the subscription edition, otherwise the web edition. both lead you to a button "SOFTWARE" just click it and follow the instructions. i highly recommend to upgrade as realy a lot of things have changed and being improved since Quartus V6 Latest Version is V9 with service pack 2 - Altera_Forum
I am trying to learn things from the Altera Online Training.
I have QuartusII and NiosII version 6.0. Do I need to and how to upgrade them? Because in SignalTapII training course it's written that it atleast requires QuartusII 8.1. I am not using hardware flow control but I am checking other things also as you have mentioned. Thanks for the great help!!! - Altera_Forum
if you do not receive a character, check if your uart is setup as hardware flow control. if that is the case and your rts cts are not correctly setup then the uart will not transmit a character, but you would see that in debuging mode.
signal tap is tool you can add inside quartus. you need to add inside signal tap the stuff you want to monitor and then need to recompile your design. once signal tap is added you can monitor these signals with quartus. recheck your pin definition maybe you have reversed txd rxd direction, a common mistake. i highly recommend to have a look at the hardware pins to see if the change their levels when you try to send out a character. altera has some guides on their web site
