DBohr1
7 years agoThermal properties change from Altera P/N EP2AGX45DF25I3N (EOL) to EP2AGX45DF25I3G.
We are evaluating the change from Altera P/N EP2AGX45DF25I3N (EOL) to EP2AGX45DF25I3G. The spec for EP2AGX45DF25I3N is lidless, and EP2AGX45DF25I3G is molded thermal composite. The data from the w...
JonWay_altera
7 years agoHi DBohr1
The only difference is the suffix "G".
And the reason for changing N to G is due to RoHS (fully lead free).
https://www.intel.la/content/dam/www/programmable/us/en/pdfs/literature/pcn/pdn1926.pdf
Everything else is the same.
- JonWay_altera7 years ago
Correction to previous:
The molded has slightly a bigger surface area. Logically, thermally should not affect much. For dimension details you can refer to:
https://www.intel.com/content/www/us/en/programmable/support/literature/lit-index/lit-pkg/package.html?family=Arria_II
