16 years agothere is no .sof file after compilation
I encounter a very strange problem. The project didn't produce the .sof file after the full compilation. What's happened ?? Thanks in advance cheng_bei
16 years agoI had a similar problem with Quartus II 10 no SP and the Cyclone IV in F23 case. If you are working in this way you should update your software to SP1 at first.
