There is no hardware in my programmer tool ,how can I do?
I’m using PL-BYTEBLASTER2N programmer,but i can't find any hardware information in program tool 17.0,my computer doesn't have Paralleler Mund,but I have inserted a PCI-Paralleler,and its driver is normal.how can I do?
- JohnT_Altera
Byteblaster is no longer supported in latest Quartus. Please refer to https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd07252010_524.html
- a_x_h_75
Contributor
ByteBlaster support was dropped from Quartus 10.0.
Refer to this page:
You should be able to install a driver manually by following the instructions.
Cheers,
Alex
- 钱44
I have been tried to install the driver but fail,I can't recieve any feedback when I run the command in CMD
- JOHI
Contributor
I do not use PL-BYTEBLASERT2N myself, but I other programming devices such as usb-blaster require that you install the driver manually, (and some devices only appear in quartus once the programming cable is connected to your DUT.)
Johi.
