There are a lot of IPs that can't be found in IP Catalog
Hi there,
I tried to install patch ''quartus-18.1std-0.05std-windows.exe'' to Quartus Std 18.1. Seems like there is no problem with ip catalog on my end. The patch probably should not have any problem.
OS system: Windows 10 64 bit (OS Build 19042.1415)
Sheng
Thank you for your reply,
It seems like something is wrong with my computer. I use the same installation to install on another computer and it works fine.
Although I didn't find in-system sources and probes on the IP catalog, it works when I generate an IP core from another computer and copy it onto my computer.
- ShengN_altera4 years ago
The Intel® Quartus® Prime software searches for IP cores in the project directory, in the Intel® Quartus® Prime installation directory, and in the IP search path.
Make sure also the ip cores file is in the Intel® Quartus® Prime installation directory. If not, you may need to locate the ip cores file path by going to Tools > Options > IP Catalog SearchLocations
Sheng - ShengN_altera4 years ago
Did you install the software with antivirus on? Temporary turning off your antivirus software may help.
Sheng
