There are a lot of IPs that can't be found in IP Catalog
That is very strange. I'd do a complete uninstall and reinstall of the software.
- 幸运的电子狗4 years ago
Yes, even if I use the tool to completely uninstall (including the registry) and then reinstall it. As I mentioned in the article, for this reason I changed to the latest version of quartus prime is also not solvable. This seems to have been caused after I installed ''patch 0.05'' and I was able to use it normally until then.
- sstrell4 years ago
Did you or do you have other versions of Quartus installed on the same machine? Quartus is picking up this list of IP from somewhere local, so all I can guess is that it might be seeing a different installation. Delete all versions of Quartus you have installed, and restart. Check your environment variables too to see if maybe there is an older path pointer in there that is affecting things.
