15 years agoThe .vho generated is wrong?
Hi
I have a problem with the .vho file generated by Quartus. When I make a complete compilation in Quartus, everything goes well. The functional simulation in Modelsim is good, timings too. But when I want to do the back-annotation simulation with the .vho generated, I get errors in Modelsim. Here the error:# vsim -do {do analyser_wave.do; run -all} -i –sdftyp /DUT=/Switch/timing/custom/switch_vhd.sdo -t ns -novopt work.switch_top
# Loading std.standard
# Loading ieee.std_logic_1164(body)
# Loading std.textio(body)
# Loading ieee.vital_timing(body)
# Loading ieee.vital_primitives(body)
# Loading altera.dffeas_pack
# Loading altera.altera_primitives_components
# Loading stratixiv.stratixiv_atom_pack(body)
# Loading stratixiv.stratixiv_components
# Refreshing /Switch/simu_post_routage/work.switch_top(structure)
# Loading work.switch_top(structure)
# ** Warning: (vsim-3479) Time unit 'ps' is less than the simulator resolution (1ns).
# Time: 0 ns Iteration: 0 Region: /
# SDF 6.6c Compiler 2010.08 Aug 23 2010
# Loading stratixiv.stratixiv_pllpack(body)
# Loading ieee.std_logic_arith(body)
# Loading ieee.std_logic_unsigned(body)
# Loading stratixiv.stratixiv_pll(vital_pll)
# Loading stratixiv.stratixiv_mn_cntr(behave)
# Loading stratixiv.stratixiv_scale_cntr(behave)
# Loading stratixiv.stratixiv_lcell_comb(vital_lcell_comb)
# Loading altera.dffeas(vital_dffeas)
# Loading stratixiv.stratixiv_ram_block(block_arch)
# ** Fatal: (vsim-3348) Port size (4) does not match actual size (144) for port '/switch_top/\DUT|the_MAC_System_0|mac_system_0|the_triple_speed_ethernet_0|altera_tse_mac_inst|top_gen_host_inst|U_MAC_TOP|U_MAC|U_TXFF|TX_DATA|U_RAM|altsyncram_component|auto_generated|ram_block1a32\/portadatain'.
# Time: 0 ns Iteration: 0 Instance: /switch_top/\DUT|the_MAC_System_0|mac_system_0|the_triple_speed_ethernet_0|altera_tse_mac_inst|top_gen_host_inst|U_MAC_TOP|U_MAC|U_TXFF|TX_DATA|U_RAM|altsyncram_component|auto_generated|ram_block1a32\ File: /home/soft/Altera/10.1/Linux/RHEL4_2.6/quartus/eda/sim_lib/stratixiv_atoms.vhd Line: 3033
# FATAL ERROR while loading design
I don’t understand because it seems that the .vho generated is wrong..? What do you think? An idea of what I can do? Thanks1 Reply
Hi
I looked in the .vho and I don’t understand. It creates a signal of 144 bits:
It initializes it with 140 gnd and 4 useful bits:SIGNAL \DUT|the_MAC_System_0|mac_system_0|the_triple_speed_ethernet_0|altera_tse_mac_inst|top_gen_host_inst|U_MAC_TOP|U_MAC|U_TXFF|TX_DATA|U_RAM|altsyncram_component|auto_generated|ram_block1a32_PORTADATAIN_bus\ : std_logic_vector(143 DOWNTO 0);
But when it instantiates the component, it gives it just a bus of 4 bits:\DUT|the_MAC_System_0|mac_system_0|the_triple_speed_ethernet_0|altera_tse_mac_inst|top_gen_host_inst|U_MAC_TOP|U_MAC|U_TXFF|TX_DATA|U_RAM|altsyncram_component|auto_generated|ram_block1a32_PORTADATAIN_bus\ <= (gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & gnd & \DUT|the_MAC_System_0|mac_system_0|the_triple_speed_ethernet_0|altera_tse_mac_inst|top_gen_host_inst|U_MAC_TOP|U_MAC|U_TXFF|data_din~0_combout\ & \DUT|the_MAC_System_0|mac_system_0|the_triple_speed_ethernet_0|altera_tse_mac_inst|top_gen_host_inst|U_MAC_TOP|U_MAC|U_TXFF|data_din~1_combout\ & \DUT|the_MAC_System_0|mac_system_0|the_triple_speed_ethernet_0|altera_tse_mac_inst|top_gen_host_inst|U_MAC_TOP|U_MAC|U_TXFF|data_din~2_combout\ & \DUT|the_MAC_System_0|mac_system_0|the_triple_speed_ethernet_0|altera_tse_mac_inst|top_gen_host_inst|U_MAC_TOP|U_MAC|U_TXFF|sop_tmp~q\);
Any idea what is wrong? Thank you-- Location: M9K_X62_Y21_N0 \DUT|the_MAC_System_0|mac_system_0|the_triple_speed_ethernet_0|altera_tse_mac_inst|top_gen_host_inst|U_MAC_TOP|U_MAC|U_TXFF|TX_DATA|U_RAM|altsyncram_component|auto_generated|ram_block1a32\ : stratixiv_ram_block -- pragma translate_off GENERIC MAP ( clk0_core_clock_enable => "ena0", clk0_input_clock_enable => "ena2", clk1_core_clock_enable => "ena3", clk1_input_clock_enable => "ena3", clock_duty_cycle_dependence => "on", data_interleave_offset_in_bits => 1, data_interleave_width_in_bits => 1, logical_ram_name => "switch:DUT|MAC_System_0:the_MAC_System_0|MAC_System:mac_system_0|triple_speed_ethernet_0:the_triple_speed_ethernet_0|altera_tse_mac:altera_tse_mac_inst|altera_tse_top_gen_host:top_gen_host_inst|altera_tse_top_w_fifo_10_100_1000:U_MAC_TOP|altera_tse_top_w_fifo:U_MAC|altera_tse_tx_min_ff:U_TXFF|altera_tse_a_fifo_opt_1246:TX_DATA|altera_tse_altsyncram_dpm_fifo:U_RAM|altsyncram:altsyncram_component|altsyncram_g1k1:auto_generated|ALTSYNCRAM", mixed_port_feed_through_mode => "dont_care", operation_mode => "dual_port", port_a_address_clear => "none", port_a_address_width => 11, port_a_byte_enable_clock => "none", port_a_data_out_clear => "none", port_a_data_out_clock => "none", port_a_data_width => 4, port_a_first_address => 0, port_a_first_bit_number => 32, port_a_last_address => 2047, port_a_logical_ram_depth => 2048, port_a_logical_ram_width => 36, port_a_read_during_write_mode => "new_data_no_nbe_read", port_b_address_clear => "none", port_b_address_clock => "clock1", port_b_address_width => 11, port_b_data_out_clear => "none", port_b_data_out_clock => "none", port_b_data_width => 4, port_b_first_address => 0, port_b_first_bit_number => 32, port_b_last_address => 2047, port_b_logical_ram_depth => 2048, port_b_logical_ram_width => 36, port_b_read_during_write_mode => "new_data_no_nbe_read", port_b_read_enable_clock => "clock1", ram_block_type => "M9K") -- pragma translate_on PORT MAP ( portawe => \DUT|the_MAC_System_0|mac_system_0|the_triple_speed_ethernet_0|altera_tse_mac_inst|top_gen_host_inst|U_MAC_TOP|U_MAC|U_TXFF|comb~0_combout\, portbre => VCC, clk0 => \DUT_PLL|altpll_component|auto_generated|wire_pll1_clk~clkctrl_outclk\, clk1 => \DUT_PLL|altpll_component|auto_generated|wire_pll1_clk~clkctrl_outclk\, ena0 => \DUT|the_MAC_System_0|mac_system_0|the_triple_speed_ethernet_0|altera_tse_mac_inst|top_gen_host_inst|U_MAC_TOP|U_MAC|U_TXFF|comb~0_combout\, ena2 => VCC, ena3 => VCC, portadatain => \DUT|the_MAC_System_0|mac_system_0|the_triple_speed_ethernet_0|altera_tse_mac_inst|top_gen_host_inst|U_MAC_TOP|U_MAC|U_TXFF|TX_DATA|U_RAM|altsyncram_component|auto_generated|ram_block1a32_PORTADATAIN_bus\, portaaddr => \DUT|the_MAC_System_0|mac_system_0|the_triple_speed_ethernet_0|altera_tse_mac_inst|top_gen_host_inst|U_MAC_TOP|U_MAC|U_TXFF|TX_DATA|U_RAM|altsyncram_component|auto_generated|ram_block1a32_PORTAADDR_bus\, portbaddr => \DUT|the_MAC_System_0|mac_system_0|the_triple_speed_ethernet_0|altera_tse_mac_inst|top_gen_host_inst|U_MAC_TOP|U_MAC|U_TXFF|TX_DATA|U_RAM|altsyncram_component|auto_generated|ram_block1a32_PORTBADDR_bus\, devclrn => ww_devclrn, devpor => ww_devpor, portbdataout => \DUT|the_MAC_System_0|mac_system_0|the_triple_speed_ethernet_0|altera_tse_mac_inst|top_gen_host_inst|U_MAC_TOP|U_MAC|U_TXFF|TX_DATA|U_RAM|altsyncram_component|auto_generated|ram_block1a32_PORTBDATAOUT_bus\);
