gongmh
2 years agoThe question about Intel Arria10 HPS mounting NorFlash write
hello, The models and quartus versions I am currently using are as follows: FPGA: 10AS032E2F2912SG Writing software: Nios II Command Shall(Quartus Prime Pro 20.3) Question: GigaDevice NorFlash, m...
tehjingy_Altera
2 years agoHi
I am Jingyang and am assigned to your case.
Would like to know more about your current situation.
Have you successfully flash the flash on your end?
The quartus programmer only supports QSPI and NAND Flash.
Jingyang, Teh
- gongmh2 years ago
hello,
Current situation: we can only use the IC Prog to burn FLASH, but we can not use the Quartus command line or graphical interface tool.
this results we need to weld the chip for writing during the debugging phase when boot update every time.
gongmh
