17 years ago
The problem of reading the data of the memory
hello!
i know the address of memory and i want to read the data.
for example:
i know the address of SDRAM is 0x01000000,
what should i do to read the data from the SDRAM.
thanks in advance.
    You can use C pointers for that.
    Do you also use the sdram to store the software itself? In that case you'll have to use a memory allocation function, such as malloc(), to allocate a memory area. If not, you can just get the address and size of your memory area from system.h.
    yes i have a sdram controller;
    i want to read the data from the address through the application.
    thank you very much.
    Do you use a SDRAM controller?
    Do you want to access it from a CPU or from custom hardware?
