10 years ago
The pin VCCPGM power supply at AS mode
Hi all,
The pin VCCPGM power supply must be 3.0v/3.3v at AS mode in the cyclone v datasheet. why?
I select a 1.8v low voltage flash from cypress. Can I connet VCCPGM pin to 1.8v?
Jimmy
    --- Quote Start ---
    I think no. EPCQ-L device runs on 1.8V VCC, but CycloneV doesn't support EPCQ-L, only EPCQ device. If it runs 1.8V VCCPGM, CycloneV will support EPCQ-L devices. So I don't think 1.8V cypress flash work instead of EPCS.
    --- Quote End ---
    I use the 1.8v spi flash from cypress at as mode successfully, and it runs 1.8V VCCPGM.
    But I still worry about the reliability.
    How can i get the further help.
    --- Quote Start ---
    as mode is for epcq or epcs shipped by altera. no cypress device. you may miss understand ps or fpp configuration, 2.5 and 1.8v are also available for these configuration mode.
    --- Quote End ---
    I replace the epcs with a cypress small outline 3.3v spi flash successfully.
    In order to reduce power cosumption, I plan to use the 1.8v spi flash from cypress now. Can i do it?
