10 years agoThe pin VCCPGM power supply at AS mode
Hi all, The pin VCCPGM power supply must be 3.0v/3.3v at AS mode in the cyclone v datasheet. why? I select a 1.8v low voltage flash from cypress. Can I connet VCCPGM pin to 1.8v? Thanks...
10 years ago --- Quote Start --- as mode is for epcq or epcs shipped by altera. no cypress device. you may miss understand ps or fpp configuration, 2.5 and 1.8v are also available for these configuration mode. --- Quote End --- I replace the epcs with a cypress small outline 3.3v spi flash successfully. In order to reduce power cosumption, I plan to use the 1.8v spi flash from cypress now. Can i do it?
