raviganesh
4 years agoThe future for AHDL
AHDL is wonderful language. I have worked on 4 HDL languages, ABEL, AHDL, Verilog and currenlty SpinalHdl.
Here is my recent work with SpinalHdl
On some aspects like an array of modules, AHDL o...
raviganesh
4 years agoHi Donald,
Here is my challenge. Now it is an array of 16 counters each with a synchronous reset.
This is the AHDL code:
SUBDESIGN counts ( clk : Input; rst[15..0] : Input; cnt[15..0][7..0] : Output; ) VARAIBLE myCnt[15..0] : LPM_COUNTER WITH (LPM_WIDTH=8, LPM_DIRECTION = "UP"); BEGIN myCnt[].clock = clk; myCnt[].sclr = rst[]; cnt[][] = myCnt[].q[]; END;
SpinalHDL
class counters () extends Component { val rst = in Bits (16 bits) val cnt = out Vec (Reg(UInt (8 bits)), 16) for (i <- 0 to 15) { when (rst(i)){ cnt(i) := 0 } otherwise { cnt(i) := cnt(i)+1 } } }
Do you want to reconsider your views on AHDL "it is very inefficient in terms of time and manpower requirements."
I do not code much in Verilog, but this is the Verilog code generated by SpinalHdl. I hope it can be a better and human readable. I await your comments.
// Generator : SpinalHDL v1.6.4 git head : 598c18959149eb18e5eee5b0aa3eef01ecaa41a1 // Component : counters `timescale 1ns/1ps module counters ( input [15:0] rst, output reg [7:0] cnt_0, output reg [7:0] cnt_1, output reg [7:0] cnt_2, output reg [7:0] cnt_3, output reg [7:0] cnt_4, output reg [7:0] cnt_5, output reg [7:0] cnt_6, output reg [7:0] cnt_7, output reg [7:0] cnt_8, output reg [7:0] cnt_9, output reg [7:0] cnt_10, output reg [7:0] cnt_11, output reg [7:0] cnt_12, output reg [7:0] cnt_13, output reg [7:0] cnt_14, output reg [7:0] cnt_15, input clk, input reset ); wire N1_l20; wire N1_l20_1; wire N1_l20_2; wire N1_l20_3; wire N1_l20_4; wire N1_l20_5; wire N1_l20_6; wire N1_l20_7; wire N1_l20_8; wire N1_l20_9; wire N1_l20_10; wire N1_l20_11; wire N1_l20_12; wire N1_l20_13; wire N1_l20_14; wire N1_l20_15; assign N1_l20 = rst[0]; assign N1_l20_1 = rst[1]; assign N1_l20_2 = rst[2]; assign N1_l20_3 = rst[3]; assign N1_l20_4 = rst[4]; assign N1_l20_5 = rst[5]; assign N1_l20_6 = rst[6]; assign N1_l20_7 = rst[7]; assign N1_l20_8 = rst[8]; assign N1_l20_9 = rst[9]; assign N1_l20_10 = rst[10]; assign N1_l20_11 = rst[11]; assign N1_l20_12 = rst[12]; assign N1_l20_13 = rst[13]; assign N1_l20_14 = rst[14]; assign N1_l20_15 = rst[15]; always @(posedge clk) begin if(N1_l20) begin cnt_0 <= 8'h0; end else begin cnt_0 <= (cnt_0 + 8'h01); end if(N1_l20_1) begin cnt_1 <= 8'h0; end else begin cnt_1 <= (cnt_1 + 8'h01); end if(N1_l20_2) begin cnt_2 <= 8'h0; end else begin cnt_2 <= (cnt_2 + 8'h01); end if(N1_l20_3) begin cnt_3 <= 8'h0; end else begin cnt_3 <= (cnt_3 + 8'h01); end if(N1_l20_4) begin cnt_4 <= 8'h0; end else begin cnt_4 <= (cnt_4 + 8'h01); end if(N1_l20_5) begin cnt_5 <= 8'h0; end else begin cnt_5 <= (cnt_5 + 8'h01); end if(N1_l20_6) begin cnt_6 <= 8'h0; end else begin cnt_6 <= (cnt_6 + 8'h01); end if(N1_l20_7) begin cnt_7 <= 8'h0; end else begin cnt_7 <= (cnt_7 + 8'h01); end if(N1_l20_8) begin cnt_8 <= 8'h0; end else begin cnt_8 <= (cnt_8 + 8'h01); end if(N1_l20_9) begin cnt_9 <= 8'h0; end else begin cnt_9 <= (cnt_9 + 8'h01); end if(N1_l20_10) begin cnt_10 <= 8'h0; end else begin cnt_10 <= (cnt_10 + 8'h01); end if(N1_l20_11) begin cnt_11 <= 8'h0; end else begin cnt_11 <= (cnt_11 + 8'h01); end if(N1_l20_12) begin cnt_12 <= 8'h0; end else begin cnt_12 <= (cnt_12 + 8'h01); end if(N1_l20_13) begin cnt_13 <= 8'h0; end else begin cnt_13 <= (cnt_13 + 8'h01); end if(N1_l20_14) begin cnt_14 <= 8'h0; end else begin cnt_14 <= (cnt_14 + 8'h01); end if(N1_l20_15) begin cnt_15 <= 8'h0; end else begin cnt_15 <= (cnt_15 + 8'h01); end end endmodule
