16 years agoThe end of AHDL?
Hello, was wondering what people thought about Altera's decision to remove the simulator within Quartus in version 10.0? Does this mean that AHDL will eventually die? I don't know of any other simula...
16 years agoFuture versions of Quartus II will not support a simulator. You will need to use ModelSim. Version 9.1 will be the last version to include a simulator. Hello ModelSim and testbenches!
------ In the Quartus II software version 10.0 and onwards, the Quartus II simulator and Waveform Editor is removed. Therefore, you can run your simulation in the EDA simulators. The following EDA simulators are supported in the Quartus II software: │ ModelSim │ ModelSim SE │ ModelSim Altera Edition (AE) │ ModelSim Altera Starter Edition (ASE) │ VCS/VCS-MX │ NCSim │ Active-HDL │ Riviera-PRO http://www.altera.com/literature/hb/qts/qts_qii53017.pdf?gsa_pos=1&wt.oss_r=1&wt.oss=simulation%20quartus%20ii%20handbook&gsa_pos=5&wt.oss_r=1&wt.oss=altera%20simulator%20removed%20from%20quartus
