19 years agoThe dreaded level converters
With IO voltages even lower than the attached controller one has to interface the FPGA with a level converter. Our local altera distributors support suggested the FST3245, an 8 bit parallel analog sw...
19 years agoDear M. Tschaggelar
you can use the FST3245MTC - EBV has them on stock also for small quant. http://www.fairchildsemi.com/ds/fs/fst3245.pdf Or the ultimative solution: ST2378ETTR http://www.st.com/stonline/products/literature/ds/9489/st2378e.pdf also from EBV. regards Daniel
