9 years agothe difference between a general clock inputs
I am designing a new board with 5CEFA5F23I7 device. Can you please explain what is the difference between a general clock input for example pins : H16,H15 - CLK11p,CLK11n to the clock in...
9 years agoThe difference between the pins is they connect to different set of clock resources.
If you don't care which clock resource you are connecting to, then you don't care about the differences between the pins. The topic can be either extremely important (critical) or it can be "don't care" for many applications.
