12 years agoThe Avalon-MM slave interface in the Rapidio IP core
Hello The Concentrator module provides an Avalon-MM slave interface that accesses all configuration registers in the RapidIO IPcore. while i was configing the IO module registers through the Ava...
12 years agohello ,thank you for your help
now ,i meet a new question:i can't find how to configure the signal io_s_address[31:3] (the signal of IO slave module) and when i use the signaltap to capture the signal packet_transmitted,it was always low_level,that means the packet wasn't send out of the IP core .i want to know what may cause the signal packet_transmitted always low_level?(i has already configured the IO slave module's registers) I'm looking foraward your help,thank you
