12 years agoThe Avalon-MM slave interface in the Rapidio IP core
Hello The Concentrator module provides an Avalon-MM slave interface that accesses all configuration registers in the RapidIO IPcore. while i was configing the IO module registers through the Ava...
12 years agoWhat you're describing clearly doesn't tie up with what you're seeing. I suspect your code isn't connected up as you think it is or need it to be.
Do you want to post some of the code and we can have a look?
