19 years agoTesting of internal resources
Does anyone have a simple code set for testing internal FPGA resources to aide in creating a BIST type test methodology. Something like a LUT based Pattern generator, the block to be tested (LU...
19 years agoThe CRC_ERROR is available in Stratix and later FPGA devices. It is useful for checking the CRAM bits (Configuration data in the device). So knowing that Altera devices are 100% tested and that the device is still correctly configured if CRC_ERROR pin is not flagging an error should be good enough.
