14 years agotest bench problem
sir, i have written a test bench code for my fft processor.here i used .text to import input data into test bench.vhd,but in output it shows only one input through out the simulation cycle. below...
14 years agodoes "infile1.txt" exist? is it being read correctly? with your code, if there is a problem with the file there is no message telling you this, it just skips the input code.
Try adding this to your infile process: assert (not ENDFILE(inFile) ) report "Reached end of file or there was an error" severity failure. also, with your code, a meta value on the input_tmp would return a 0 to rxn_re. Btw, its a bad habit to leave large bits of code commented out. And Please use the code tags around your code next time.
