14 years agotest bench problem
sir, i have written a test bench code for my fft processor.here i used .text to import input data into test bench.vhd,but in output it shows only one input through out the simulation cycle. below...
14 years agoI have used that code style for a decade and it always works.
Now, is your file there and correct format. Are you looking at first node that acquires data from file... you need to follow the problem step by step.
