14 years agotest bench problem
sir, i have written a test bench code for my fft processor.here i used .text to import input data into test bench.vhd,but in output it shows only one input through out the simulation cycle. below...
14 years agosir, i have moidfied my code as per youe advice .but in waveform i get "0 " values for iput & output. i have done the simulation for 1000us.plz help:cry:.i have attched the output waveform . code is here...
LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.std_logic_unsigned.all; USE ieee.numeric_std.ALL; USE IEEE.STD_LOGIC_TEXTIO.ALL; USE STD.TEXTIO.ALL; ENTITY x_tb_rfft IS END x_tb_rfft; ARCHITECTURE behavior OF x_tb_rfft IS -- Component Declaration for the Unit Under Test (UUT) COMPONENT rfft_core PORT( rxn_re : IN std_logic_vector(7 downto 0); rxn_im : IN std_logic_vector(7 downto 0); rsclr : IN std_logic; rce : IN std_logic; rclk : IN std_logic; rstart : IN std_logic; runload : IN std_logic; rfwd_inv : IN std_logic; rfwd_inv_we : IN std_logic; rxk_re : OUT std_logic_vector(18 downto 0); rxk_im : OUT std_logic_vector(18 downto 0); rxn_index : OUT std_logic_vector(9 downto 0); rxk_index : OUT std_logic_vector(9 downto 0); rrfd : OUT std_logic; rbusy : OUT std_logic; rdv : OUT std_logic; redone : OUT std_logic; rdone : OUT std_logic ); END COMPONENT; --Inputs signal rxn_re : std_logic_vector(7 downto 0) := (others => '0'); signal rxn_im : std_logic_vector(7 downto 0) := (others => '0'); signal rsclr : std_logic := '0'; signal rce : std_logic := '1'; signal rclk : std_logic := '0'; signal rstart : std_logic := '0'; signal runload : std_logic := '0'; signal rfwd_inv : std_logic := '1'; signal rfwd_inv_we : std_logic := '0'; --Outputs signal rxk_re : std_logic_vector(18 downto 0); signal rxk_im : std_logic_vector(18 downto 0); signal rxn_index : std_logic_vector(9 downto 0); signal rxk_index : std_logic_vector(9 downto 0); signal rrfd : std_logic; signal rbusy : std_logic; signal rdv : std_logic; signal redone : std_logic; signal rdone : std_logic; SIGNAL newValueRead : BOOLEAN := TRUE; SIGNAL newValueToSave : BOOLEAN := FALSE; --signal count : std_logic_vector (10 DownTo 0) :="00000000000" ; signal No_of_elements_read : integer := 0; SIGNAL result : std_logic_vector (37 DownTo 0) := "00000000000000000000000000000000000000"; --Constants constant PERIOD : time := 20 ns; constant DUTY_CYCLE : real := 0.5; constant OFFSET : time := 10 ns; BEGIN -- Instantiate the Unit Under Test (UUT) uut: rfft_core PORT MAP ( rxn_re => rxn_re, rxn_im => rxn_im, rsclr => rsclr, rce => rce, rclk => rclk, rstart => rstart, runload => runload, rfwd_inv => rfwd_inv, rfwd_inv_we => rfwd_inv_we, rxk_re => rxk_re, rxk_im => rxk_im, rxn_index => rxn_index, rxk_index => rxk_index, rrfd => rrfd, rbusy => rbusy, rdv => rdv, redone => redone, rdone => rdone ); ---clock: PROCESS -- clock process for clk ---- BEGIN --WAIT for OFFSET; ----- CLOCK_LOOP : LOOP ------- rclk <= '0'; ------- WAIT FOR (PERIOD - (PERIOD * DUTY_CYCLE)); ------ rclk <= '1'; --------count<=count+"00000000001"; ----------if (count="11111100000") THEN ------- WAIT; -- wait for ever. -------- end if; ------ WAIT FOR (PERIOD * DUTY_CYCLE); ----------- END LOOP CLOCK_LOOP; ------END PROCESS clock; rclk <= not rclk after 10 ns; generate_rst_fwd_inv_we_n_start: process begin WAIT for OFFSET; rsclr <='1'; rstart<='1' after 20 ns; rstart<='0' after 40 ns; wait until (rising_edge(rclk)); ----wait for PERIOD; -------rsclr <='0'; ----rfwd_inv_we<='1'; --wait for PERIOD; ---rstart<='1'; ---rfwd_inv_we<='0'; ---wait for PERIOD; ----rstart<='0'; -----wait; end process; readProcess :PROCESS (rclk) is file inFile:TEXT open READ_MODE is "infile1.txt"; VARIABLE inLine : LINE; variable input_tmp : integer := 0; ------ variable ar_var : std_logic_vector (7 DownTo 0); -------- variable ai_var : std_logic_vector (7 DownTo 0):= (others =>'0'); begin if(rising_edge(rclk))then if rrfd = '1' then if not endfile(inFile)then readline(inFile,inline); read(inLine,input_tmp); rxn_re <= std_logic_vector(to_signed(input_tmp,8)); end if; end if; end if; end process; ------ WAIT UNTIL (rclk = '1' AND rclk'EVENT); -----IF (NOT ENDFILE(inFile)) and rrfd ='1' THEN --(NOT ENDFILE(inFile)) and rrfd ------ READLINE(inFile, inLine); ------- READ(inLine, ar_var); -- READ(inLine, ai_var); -----rxn_re(7 downto 0)<=ar_var; --- rxn_im(7 downto 0)<=ai_var; ----- No_of_elements_read <= No_of_elements_read+1; ------END IF; --------END PROCESS readProcess; result <= rxk_re & rxk_im; OutputControl: PROCESS(rclk) --output the result at right time. BEGIN if rdv='1' then newValueToSave <= TRUE; else newValueToSave <= FALSE; end if; end process OutputControl; Generate_unLoadSignal: process--(rclk) -- assert unload signal pulse. begin -----wait until (rclk = '1' and rclk'event); ------if ( rbusy = '1' and redone = '1') then -------runload <= '1'; ---else ----runload <='0'; -------end if; if rdone'event and rdone= '0' then runload <= '1'; wait for PERIOD; else if rdone='0' then runload <= '0'; end if; end if; wait on rclk; end process Generate_unLoadSignal; WriteProcess : PROCESS file outFile:TEXT open WRITE_MODE is "outfile1.txt"; VARIABLE outLine : LINE; BEGIN WAIT UNTIL rclk = '1' AND rclk'EVENT; IF (newValueToSave = TRUE) THEN WRITE(outLine, result, right, 38); WRITELINE(outFile, outLine); END IF; END PROCESS WriteProcess ; END; file:///C:/Documents%20and%20Settings/Debolina/Desktop/wvft.JPG
