14 years agotest bench problem
sir, i have written a test bench code for my fft processor.here i used .text to import input data into test bench.vhd,but in output it shows only one input through out the simulation cycle. below...
14 years agoAre you saying your read is reading one data only?
try this
process(clk)
file file_in : text open read_mode is "datain.txt";
variable line_in : line;
variable input_tmp : integer := 0;
begin
if(rising_edge(clk))then
if read_input = '1' then
if not endfile(file_in)then
readline(file_in,line_in);
read(line_in,input_tmp);
data_in <= std_logic_vector(to_signed(input_tmp,16));
end if;
end if;
end if;
end process;
