15 years agoTDI connection to the first detected device EP3C55 might be shorted to GND
I m using three Altera Cyclone IV FPGAs in a single JTAG chain(Two are EP4CE55F484 and one is EP4CE10F256).In that EP4CE10F256 is having a separate EPCS16 in AS Configuration and having Dip Switch to select the devices for JTAG Chain. Problem is,when i m setting first device in chain,Quartus® II software version 10.0 SP1 shows the error msg like, Error: JTAG chain problem detected Error: TDI connection to the first detected device EP3C55 might be shorted to GND Error: The TCK and TMS connections to the device before the first detected device EP3C55 might have a problem Info: Detected 1 device(s) Info: Device 1: EP3C55 In JTAG Debugger also shows TDI is shrted to GND. if i m put all the devices in chain,same error appear but other to are detected well. The first device alone not programmed individually and in group. can any one Help me???No RepliesBe the first to reply
