18 years agoTcp_ip, Sopc
hello, i have a bord STRATIX II EP2S60, i use quartus 2 v7.2. i would like to use nichestack tcp/ip for nios 2, I don't know if i must use the MicroC/OS for this or i can avoid it (i don't...
18 years agoVeenu,
The patch fails because the files are different between 7.1 and 7.2. I applied the patch on a 7.1 directory than manually compared the files between 7.2 and 7.1 and manually made any pertinent changes on the 7.2 branch. Now I haven't seen your particular error before. But I'm sure we can narrow it down. Obviously the error indicates that no Ethernet interfaces are being initialized. What MAC/PHY are you using? Does everything work using the UCOSII Simple Socket Server example? Jake
