18 years agoTcp_ip, Sopc
hello, i have a bord STRATIX II EP2S60, i use quartus 2 v7.2. i would like to use nichestack tcp/ip for nios 2, I don't know if i must use the MicroC/OS for this or i can avoid it (i don't...
18 years agoYes you can run the InterNiche Stack in Superloop mode. That is how we currently use the stack for our products. Altera does not support this so there are a few minor hacks you have to make. Here is a good place to start:
http://nioswiki.jot.com/wikihome/nichestack/%22super%20loop%22%20nichestack (http://nioswiki.jot.com/wikihome/nichestack/%22super%20loop%22%20nichestack) Note that the patch available in the link is for 7.1. There are some minor differences between 7.1 and 7.2 that will require you to make some manual changes. Jake
