17 years agoSystem Library Properties
Hi, I attached my System Library Properties and my .sopc file to the thread. When doing this, I have the following error : Downloading 00010020 ( 0%) Downloading 04000000 ( 2%) Downloaded...
17 years agoHi,
Thank you for answering. I chose the followings : PLL clock frequency : 90MHz Memory clock frequency : 100MHz Local interface clock frequency : Full On the slide PHY settings, I have a clock phase of 90. Then, I included the file ddr_sdram_phy_ddr_timing.sdc (which is generated by sopc if I'm not mistaken) to the project. What should I change ? Myriam PS : I have a Cyclone III EP3C25
