14 years agoSystem ID issue
Hi everyone, I am working in a project using Quartus v11.0. The Bsp was created using Qsys. *obs: The project was updated/converted from SOPC Builder to Qsys... So, I am having pro...
14 years agoThe first return value is supposed to the the ID and the second one the timestamp.
None of the value seems even remotely close to what you have in your BSP or your first screenshot. This indicates that what you currently have in the FPGA isn't the image expected by your BSP. So check that both the BSP and the Quartus project are using the same QSys project, compile the QSys project first, then the Quartus project and the software, check that you put the correct .sof file and try again to upload your software.
