11 years agosystem console, external memory, multiple masters
Hi guys Im fairly new here. Im working with a cyclone V GX board and have used qsys to add a memory controller in my nios code to control some lpddr memory on the eval board. Im u...
11 years ago --- Quote Start --- baud rates are what is expected. --- Quote End --- And what was the solution? I assume it was realizing that you were using a 125MHz clock for everything, but performing your calculations assuming it was 50MHz, and the FTDI baud rate was correct all along? Cheers, Dave
