11 years agosystem console, external memory, multiple masters
Hi guys Im fairly new here. Im working with a cyclone V GX board and have used qsys to add a memory controller in my nios code to control some lpddr memory on the eval board. Im u...
11 years ago --- Quote Start --- So, my suspicion is that the qsys clock parameter is up to me to define. if i say its 50, and i actually give it 125MHz, then its still going to assume its 50MHz? --- Quote End --- There is no assuming anywhere. Double-click on the clock in your Qsys system and change it from its default value of 50000000 to 125000000. --- Quote Start --- Im still confused why my signal tap says 9600 baud. im tapping right at the uart TX/RX pins. thats outside the qsys realm. so you would think that the rate would already be skewed by the time it gets to the TX pin. yet, the data on the TX pin is at 9600 baud. thoughts? --- Quote End --- It depends on what clock you have connected to your SignalTap II instance. You need to confirm what clock is going to SignalTap II. Cheers, Dave
