11 years agosystem console, external memory, multiple masters
Hi guys Im fairly new here. Im working with a cyclone V GX board and have used qsys to add a memory controller in my nios code to control some lpddr memory on the eval board. Im u...
11 years agoSo i quickly tried
alt_u16 divisorSetting = IORD_ALTERA_AVALON_UART_DIVISOR(UART_0_BASE); and that spit out 5208 so doing that math, my baud rate would be 9600 I do have the "change the baudrate via SW" button checked, but it used to be disabled in a previous build. ill redo everything and see if things dont jive then But assuming that IORD_ALTERA_AVALON_UART_DIVISOR(UART_0_BASE) yields a correct divisor (i do have qsys calling for 9600), then the ftdi is modifying the qsys rate and kicking something else out. im going to look at ftdi config...
