11 years agosystem console, external memory, multiple masters
Hi guys Im fairly new here. Im working with a cyclone V GX board and have used qsys to add a memory controller in my nios code to control some lpddr memory on the eval board. Im u...
11 years agoHey Dave
Yes, you confirmed what i thought i should be looking for... A = d65, B= d66. So because my signal tap was working, i didnt want to recompile and rish that error. So, i went ahead and recompiled and triggered on TX and saw the usb rate from nios was different that what putty was kicking out. I tried adjusting the baud rate in the device manager/properties, but that does not change the bit rate on the signal tap. So, i started adjusting the rate on putty to match the trace on the signal tap. And at 24000 baud, things started working. So you were right.. its baud rate. So ive got to figure out why it works at 24000 when 1)why the driver settings have no effect on the rate 2)the qsys parameters on the usb uart are at 9600 3)nothing i see anywhere mentions 24000... i think there are baud rate multipliers somewhere that i might have to set. any ideas on where to look would be great again, thank you for bearing with me on this. i am just a little pilot fish thanks for your help!
